SignalExpress
Timed acquisition
I'm trying to acquire 10 samples at 10Hz every 60 seconds using SignalExpress 2013.
My hardware consists of a cDAQ 9174 chassis and a 9215 analog voltage input module. (I also have a 9481 relay module with counters). Is there a way to somehow trigger the acquisition of the 10 samples at 10 Hz every 60 seconds with this hardware using SignalExpress?
I tried using the 9481 counter to generate a pulse to PFI0 every 60s and use that to trigger the acquisition, but I get an error message "Specified route cannot be satisfied, because the hardware does not support it."
Any suggestions?
Thanks in advance!
(5,506 Views)
Check out this KB on triggering in SignalExpress:
http://digital.ni.com/public.nsf/allkb/9DE9E3E4DAD9EE93862579C60018B6EA
It goes through setting up the trigger source and configuring pre-trigger or post-trigger samples
-Erik S
(5,484 Views)
