SignalExpress
Slow aquistion
I am using LabView Signal Express 2012 with my TDS3014 connected via Ethernet.
When I simply start a new project, and add a step to aquire a signal, then run the step, it takes a very long time to get the signal! It's not real time (not even near) I have to wait at least a second to get the newly aquired signal. It says "Waiting for trigger" and then run. The control led on the scope for "Single seq" is flashing all the time the programm aquires the new signal.
It's like using the scope in the "Single seq" mode and pushing all the time the button to get a refresh and not using the "RUN" mode.
Greetings
(5,695 Views)
Hi there,
What values do you get when you try to ping your device in windows?
What is your PC Hardware setup?
(5,674 Views)
