SignalExpress
SignalExpress function int(x) same as floor(x)?
SignalExpress help describes the function int(x) as rounding x to the nearest integer, but it functions the same as floor(x).
For example:
y = int(x0) where x0 = 2.9, y = 2.0
y = int(x0) where x0 = 2.4, y = 2.0
y = int(x0) where x0 = -2.4, y = 3.0
y = int(x0) where x0 = -2.9, y = 3.0
y = floor(x0) where x0 = 2.9, y = 2.0
y = floor(x0) where x0 = 2.4, y = 2.0
y = floor(x0) where x0 = -2.4, y = 3.0
y = floor(x0) where x0 = -2.9, y = 3.0
where x0 is the input analog input to the USB-6009
y = ceil(x) works as advertised.  Am I missing something here?
Thanks - Bill
(6,620 Views)
Hi Bill,
You are definitely not missing something.  I was able to reproduce the incorrect function operation here on my end.  I would like to file a corrective action request on the matter, and need some information from you.  Which version of SignalExpress are you using?  Thanks!
David
David
Digital Multimeters
(6,605 Views)
Thank you, David, for the reply.  I am using SignalExpress Version 3.0.0
(6,601 Views)
Do you know of a work around for int(x)?
(6,596 Views)
