SignalExpress
Signal express Tutorial
1- I would like to explore the functions of Signal express, but I cannot find a decent "instruction manual".
If there is any please let me know.
2- I need to monitor 4 inputs and record 5 signals with my USB6009 for about 3 minutes, but with best possible resolution
as the purpose is to find motor current (50 Hz) interferences.
So, the signals are:
channel a0 instantaneous voltage (sin wave)
Channel a1 nstantaneous voltage (motor Speed A)
Channel a2 nstantaneous voltage (motor Speed B)
Channel a3 nstantaneous voltage (motor Speed C)
- rms of signal input a0
It could be good to make a continuous sampling with  20 samples in a rate of 1KHz
so, a rms should be done in each cycle  (1s/50= 20ms ).
The problem is that it comes the following error 200279.
I would like to know if there is any other technique I can use like using subsets to calculate the rms
in order to get a faster refreshing of the display.
Regards
Thank you for any kind of help.
Antonio
(11,550 Views)
You can get on our site the Getting Started with SignalExpress.
If you don't need to take a decision during the process, don't calculate the rms value before having completed the acquisition. You get the error -200279 because you are trying to read samples who have been overwritten. Do you configure a buffered acquisition? How many samples do you read?
(11,515 Views)
