SignalExpress
Signal Express
I have not used my Signal Express software in awhile. I wanted to set up an experiment  today and start recording temperature vs. time. I opened the program and in the properties tab of the data view panel I clicked on the x-axis selection to select absolute time. After making my selection I returned to the data view panel and the X-axis indicated that the current time was 6 pm on 12/31/1903. My question is: how do I set the current time and date? My new email address is pmaillot@dow.com. Thank you
(6,044 Views)
Hi labanimal-
     In SignalExpress, be sure to view the data using a time graph rather than a chart.  I just ran an acquisition, recorded it, took that data and dragged and dropped it to a time graph and selected absolute time.  It showed the current date and time.  You might also try running different acquisition modes, i.e. N samples and continuous to see if this changes the behavior.
     I hope this helps.  Best of luck with your application!
Gary P.
(6,021 Views)
