SignalExpress
Scale Output
Using SignalExpress 2012 with USB 6009
On channel 0 im measuring voltage with a 10:1 attenuator connected
How do i scale my output voltage to show the correct value that im measuring
(5,970 Views)
There is an option within the channel configuration/step setup to apply custom scaling to the channel.
James K.
(5,956 Views)
Are you refering to this secreen
If so i did see it but could not figure out how to use it
I need to amplify the resulting voltage on the screen by 10 times
(5,946 Views)
