‎04-03-2013 07:35 AM
I just installed LabVIEW 2012 SP1, and now the Signal Express application runs itself randomly. Is there a way to prevent that?
Solved! Go to Solution.
‎04-04-2013 05:25 PM
What exactly do you mean by "runs itself randomly"? Does it just open up randomly when you're using your computer, or is only when using LabVIEW? I have never ran across this issue before so I just need a little clarification so we can get to the bottom of the problem.
‎04-08-2013 07:39 AM
After a little more use, I found that it auto-runs whenever a DAQ device is detected.
I'de like for Signal Express to run only when user selects it. Thanks Dan.
Steve
‎04-09-2013 10:17 AM
So that just means the automatic startup is enabled, and this can be easily changed. The following KnowledgeBase article addresses this exact issue:
-Prevent Auto Start of Measurement & Automation Explorer or SignalExpress for USB
http://digital.ni.com/public.nsf/allkb/794E6A1E4358B865862572D000540B32?OpenDocument
