SignalExpress
Playback options
I have logged a signal in Signal Express. The logged signal was a sound spectrum adquired from a NI DAQ system. I want to choose only a portion of all spectrum, make a RMS Averaging and then create a snapshot of this Average sound spectrum portion to export to Excel. Those are the step I have done:
  1. Add Step-->Analysis-->Frequency domain measurements-->Power Spectrum.
  2. In the Averaging Label--> Averaging Mode--> RMS Averaging.
  3. In the Playback Options Label--> For example: Start time-> 12,000   Stop Time: 16,700
  4. Sweep Spectrum to Data View
My question is: Do I have to pulse "play" button to make an average of these 4,700 seconds and then create and snapshot to export to Excel?. When I pulse "play" It doesn`t make and average of this interval of time, the signal continues running. Is there any othe option to do this?
Thank you
Aitor Aramburu
Message 1 of 10
(9,339 Views)
Sorry, the signal was logged with the software "Sound and Vibration assistant".
Can anybody help me? I need a quick answer because I have to do a report this week.
Thank You
Message 2 of 10
(9,314 Views)
Aitor,
If I understand what you are doing properly you would like to get an RMS value of all of your points, or a longer moving average of the points. You can change the settings in the averaging tab to meet your specific average needs. "Pulsing" play will just do the exact same analysis repeatedly. If you want a smoother average, increase the number of averages you are using.
-Marshall R
Message 3 of 10
(9,291 Views)
Dear Marshall,
First of all thank you so much for your time. We are really interested with this topic, so hope you can help us!
You are right, this is what we are doing at this moment, but we are not sure if we are doing it correctly or not.
We are making some measurements as specified on IEC-61400-11 (noise-tones of wind generators). I don't know if you are aware of this testing or not. In any case, we have done the measurement of 2 minutes of noise, and we have to proceed as follows:
  • First of all, those 2 minutes we have to divide them into 12 spectra of 10seconds each. To do this we use the "Playback Options" - Start & Stop time manually selecting the interval.
  • Then we have to make the equivalent sound spectra of those 10s. This is where we have the question, and what we do not know if we are doing it properly or not:
    • To do this, is it correct to make it as you have specified?
    • Do we have to fix the number of averages to any special value?
    • Maybe if we give the number of averages a big value has any problem? if we fix this number a high value and then just working with 10s, we are not going to reach the "averages completed" status message, but the calculus would be correct?
  • Also, to do this, do we have to push the "play" button? or is there any other way to do it?
Message 4 of 10
(9,272 Views)
I think I better understand what you are trying to do now. The averaging options are only useful if you are interested in doing a running average of your data, in your case, I think you are more interested in the spectrum of each 10 second chuck so disable the average and record each to file programatically. We can modify our playback to do 10 second chunks and then programatically write these results to a ascii file which can be easily opened in Excel.
A Save to ASCII/LVM Step, set to record our spectrum:
This should generate you a seperate file for every chuck of 10seconds of data.
This theory could also be added to your acquesition, so if you did a Continuous  Acquesition and set the number of samples to read to 10 seconds worth, you could then implement the two steps I just did and have it write the spectrum to files as you went!
-Marshall R
Message 5 of 10
(9,251 Views)
Dear Marshall,The use of a Save to ASCII / VLM file seems to be a good idea, this makes our “hard” work much easier. Thanks for this good idea, but we still have more questions to finally solve our problem regarding the option of changing the “Block Size” in “Recording Options” tab.You proposed to change the “block size” value to fix it so that it would calculate for 10s each, and this is a good idea, but has the problem that it changes our post-processing frequency resolution. For example, we work with a sampling rate for the recording to 25.6kHz, and want a resolution of 2Hz, this way if we fix the block size value to 12800 we have the 2Hz desired resolution. Dibujo.JPGThis has the problem that if we change the value of the block size (samples) then we change also the frequency resolution, which is not desired. Do you know which way we can solve both problems at the same time?Thanks in advance!Best regards,Aitor
Message 6 of 10
(9,241 Views)
Here I think it would be best to use the subset and resample. That way you can resample to mantain the same resolution regardless of you your block size.
-Marshall R
Message 7 of 10
(9,235 Views)
Dear Marshall,
We have been doing some testing with the proposed using of "Subset and resample", but we do not have it clear. Could you please explain a bit of how using it?
The aim of our project post-processing is to have a 2Hz frequency resolution of the FFT diagram, and to be able to divide the spectrum automatically into 10s spectra. Do you know if there is an easy way of doing so?
Aitor
Message 8 of 10
(9,198 Views)
Accepted by topic author aaramburu
The following equation can help you understand the resolution of your FFT.
delta-f --  FFT resolution
fs -- sampling freq
N -- length of FFT
So if you resample to the same sampling freq relative to the length of the FFT you will get the same resolution. Note, you still need to abide by the niquest theorem to keep valid results.
More of the topic can be found here
-Marshall R
Message 9 of 10
(9,183 Views)
Dear Marshall,
Thank you so much for your time. We think this is the solution we need.
Aitor
Message 10 of 10
(9,174 Views)
