SignalExpress
Operating Signal Express with Labview 7.1
Hey,
I have just recently installed Signal Express as a portion of the Sound & Vibration Measurement Suite and teh Sound & Measurement Assistant front end works well. When I attempt to start a new VI in Labview 7.1, I am unable to insert tools from the order analysis menu.
Do I need to upgrade Labview or is there another solution
Doug
(5,633 Views)
Hello Doug.
Thank you for contacting National Instruments.
The readme of Sound and Vibration Measurement Suite 5.0 states that you must have LabVIEW 8.2 or later Full Development System or Professional Development System installed and properly licensed in order to run this application successfully. So, I hate to be the bearer of bad news, but it appears that you will not be able to use this Measurement Suite inside of LabVIEW 7.1. As further confirmation of this, do you see any S&V or Order Analysis VI's on your functions palette in LabVIEW? If you don't, this will indicate that the functionality for LabVIEW was not installed because of an incompatibility between the toolkit and the version of LabVIEW.
Let me know if I have explained this well. If there is anything else I can do for you to help you through this, please let me know. I will be more than happy to help!
Brian F
(5,624 Views)
