SignalExpress
No complex waveform in SignalExpress
Can anyone confirm that complex in/outputs of LabVIEWs dont work when you try to utilze them with SignalExpress 2009?
I just used the Execute VI - LabVIEW 2009 step with double waveform and it worked. After changing to complex waveform sgl the output did not appear.
Message 1 of 9
(7,865 Views)
Hi jojp
could you please post the VI you used for testing?
Kind regards
Carsten
Message 2 of 9
(7,854 Views)
Its a simple sinus wave generator. You can download the LLB here: http://drop.io/ni_gen_llb
You should import the gen.vi
Please note that I´m using LabVIEW 2009
Message 3 of 9
(7,849 Views)
Hi jojp,
What do you mean with complex waveform, an array of complex numbers (2+3i)+dt+t0??
Kind regards
Carsten
Message 4 of 9
(7,846 Views)
Yes, Waveform is a LabView standart format and I want to use to one with complex single precision float values.
In LabView it works perfect, but when you insert VIs with in/ouputs utilizing this features they won´t appear.
Best regards jojp
Message 5 of 9
(7,824 Views)
Hi jojp,
I found the following KB which describes the datatyps you can use when using a LabVIEW VI in Signal Express.
http://digital.ni.com/public.nsf/allkb/16C5D8013AD8EDF486256FFE007B19BC?OpenDocument
so unfortunatly you can't use complex waveforms in Signal Express
Kind regards
Carsten
NI Germany
Message 6 of 9
(7,808 Views)
Thans Carsten, found the same page before. But I thought complex is not excluded explicit.
Message 7 of 9
(7,751 Views)
You can split your real and imaginary parts into separate arrays, but you may or may not be able to do what you want with them in SignalExpress afterwards.  We are aware of this issue.
Message 8 of 9
(7,747 Views)
Hi DFG,
I thought about that, but for my project changing all LabVIEW VIs to make them fit to SE is a major drawback.
Best regards jojp
Message 9 of 9
(7,745 Views)
