01-23-2013 03:39 PM
I'm looking to control Signal Express through a TCP/UDP command sent from same network, which would enable/disable recording in SignalExpress.
Is there documentation for an API, or something that I can use to program a client to start and stop SignalExpress recording or data acquisition?
Thank you.
01-24-2013 10:30 AM
Hi DS487,
This functionality is not available for SignalExpress as it is meant to be a basic interactive tool for measurement and analysis without the need for programming. If you were using LabVIEW, what you are trying to do is certainly possible.
01-24-2013 01:17 PM
Could you please point me in that direction? I'm interested in seeing those capabilities.
01-25-2013 08:49 AM
To do this in LabVIEW, you will need to know how to handle producer/consumer loops and events. Were I to do this, I would probably write a program with three loops - one for the user interface interactions (using the event structure), one for logging, and one for monitoring the TCP/IP stack for commands. Use queues to communicate between the various loops. This is the view from 20,000ft. If you are unfamiliar with LabVIEW, I would encourage you to either take classes or run through the online tutorials. When you have questions, post them to the LabVIEW board. We have a hoard of superb users who will give you more help than you could possibly imagine (including some of us here at National Instruments).
