SignalExpress
LVM format
Hello!
I want to save data from XY Graph in the file, use function "Save to ASCII/LVM".
In the input "signals in" element of this type:
In the field "Input Data Type" - XY Waveform.
Then I want to open this file in SignalExpress, use function "Load from LVM".
Error occurs and in the field "Domain" I see only "Time waveform" and "Frequency waveform". Where is XY Waveform?
(5,550 Views)
Hi Irafka
Actually, you do not save a file as XY Graph. You do only visualize it as XY Graph. You save it as a LVM table.
When you read it, you just read from two channels and have the option to make a preview of the file you are reading.
In the load from LVM, you have to choose the file you saved and choose the channels that you saved.
Here you can see it.
(5,526 Views)
