SignalExpress
How to switch output parameters at run time
I wrote a really simple LabView program to generate a square waveform with duty cycle changing at run time...
Anyway, to change the duty cycle it has to clear the task and then restart a new one with the new duty cycle: I don`t want it, cause during this time ( between the stop and the restart ) the output is obviously at zero!!! Smiley Mad
I`d like to have a continuos sweep of the duty cycle in real time!  Smiley Sad
Is it possible to have ?
Thank you really much!
Message Edited by Jacopo on 03-26-2008 09:47 AM
(6,556 Views)
Hello Jacopo,
you can take a look at this document:
How Can I Change the Duty Cycle on My Continuous Pulse Train?
There is also an example attached at the document.
Hope this can solve your problem.
Andrea N.
Andrea N.
Principal Applications Engineer - Semiconductor EMEA
National Instruments Italy
Certified LabVIEW Architect - Certified TestStand Architect
(6,543 Views)
Thank you really much for the advise! Smiley Happy
I read the article and I found the solution at my problem! Smiley Wink
(6,539 Views)
