SignalExpress
How to program encoder pulses in Signal Express to read out in degrees
I have people requesting a Signal Express application that can display rotary machine degrees (0.0-359.9), with input from an encoder to a 6602 counter card. Can this be done in Signal Express at all and if so, what is the easiest way to program it?
(7,796 Views)
Hi Jonrie1,
Yes this can be done in Signal Express.  The easiest way is to create a DAQmx Acquire step for counter input » position » angular.
David
Digital Multimeters
(7,778 Views)
Hello David,
in the same way, i configured a linear position encoder.
In the continious sampling mode, I can't save the displacement channel.
Is there any other option to save the Channel witrh e.g. 20 kHz?
Andreas
(5,765 Views)
What hardware are you using to perform your task? I was able to reproduce the message you saw when I tried to create a counter task with anything other than one of our cDAQ chassis. When trying to create this task with a module in a cDAQ chassis, logging was available. It may be a restriction on your hardware that is preventing you from logging the displacement.
(5,751 Views)
Hello diabeticdaniel,
I use a cDAQ Chassis NI 9178 with the Modul 9401.
In between I found this, is this also your opinion:
http://forums.ni.com/t5/SignalExpress/Recording-synchronized-analog-and-encoder-inputs/m-p/2857926#M...
But I have still the problem in SignalExpress to choose a external Timing. E.g. the "20 MHz Timebase" or the "Onboard Clock" is not availible.
I need at least a 10 Mhz Clock to recognize the Signal.
(5,690 Views)
