SignalExpress
GPS with NI LabVIEW SignalExpress
I came across the application readgpstimepositionvelocity.llb and wanted to know if I can use this in LabView SignalExpress.  If not, would anyonwe know of an applcation where I can import GPS data into Signal Express.
(6,279 Views)
Hey Hoover,
You can actually run LabVIEW VI's in Signal Express.
In order to test this I actually went through this using LabVIEW 8.2 and Signal Express 3.0. The hardest part about making LabVIEW and Signal Express play nice together is that you have to create a Source Distribution and make sure that all of the subVIs from vi.lib and other dependencies are included in the same directory. If you don't have the same version of LabVIEW, then you should be able to download it for free here: https://www.ni.com/en/support/downloads/software-products/download.labview-runtime.html
There is also a lot of good information in the Signal Express help on how to use the Run LabVIEW x.x VI steps.
I hope this helps!
Message Edited by Lars_L on 04-02-2009 05:42 PM
(6,247 Views)
