SignalExpress
Error 200561: Analog Voltage output for thermocouple inputs
Hello all,
I'm using SignalExpress to read temperatures off a thermocouple  (from an ai channel) and then output the voltage as it is to a board (through an ao channel). However, if I happen to have a temperature that is out of the voltage range (+10 V to -10 V) such as 20 deg C, it reports error 200561 and does'nt output it. This problem has been dealt with before, but in a LabVIEW VIs, however my problem is specific to SignalExpress. Any ideas how to get around this problem.
Help greatly appreciated,
Ronak
(6,732 Views)
Your options for coercion are more limited in Signal Express than in LabVIEW. Can you try using a “Conditional Repeat” block into your code? This should give you the ability to generate only when the data in within range.
Matt
(6,698 Views)
