SignalExpress
Error 200077 occurred at DAQ assistant
Upon "run" mode of my program this DAQ assistance root occurs.
Porperty:Pre scaled units
requested value:mVolts/Volts
You Can Select: Newtons
However when I do this I get the same error.
I am using an NI9237 with NI-DAQmx,  I have 4 load cells each with there calibration data entered into the tables. My original problem was how to zero but now its doing this.
I am ready to package this mess up and ship it back! Is there something I don't understand?????
La-Z-Man
(5,901 Views)
La-Z-Man,
Could you provide a screenshot of your SignalExpress configuration for your input step?  I'd like to simulate the hardware and test it with your parameters to see if I can replicate what you're seeing and figure out what's going wrong.
(5,889 Views)
