SignalExpress
Analog Output Signal Problem
Hello all,
I'm new to LabView, so I hope you can give me a little support.
I created an analog output signal (sine wave) in SignalExpress. I want to run this signal continuously.
I used a sample rate of 1000 S/s, a block size (samples) of 100 and a frequency of 10 Hz.
By looking at my output signal, I can see a a short interrupt after every 100 samples.
Is there any chance to run the signal continuously without an interruption after every iteration?
Thank you for your help
(5,524 Views)
I need more information about your project. Is it possible that you give it online?
Maybe you create a signal which has as a acquisition mode finite. Maybe when you made it as continious there will be no interrupt.
Regards
(5,497 Views)
