Signal Generators
trigger line conflicts
Hi Tony
Are you mapping triggers manuallly?  Then you also need to reserve the lines in MAX. Otherwise, TClk will grab the same lines and they will get double driven.
J
Message 11 of 21
(5,706 Views)
I reserved the lines that we use (1-5), the MapTrigger calls no longer return errors but the unmapTrigger calls still return the same error.
Message Edited by tonys10 on 02-02-2006 05:43 PM
Message 12 of 21
(5,700 Views)
I have been playing with reserving trigger lines in max and it is still a bit inconsistent. The routing is "Dynamic" for all channels and Triggers 1-3 will only be used on Bus 2 and Triggers 4 & 5 will only be used on Bus 3. In addition I am using Trigger 6 for the start trigger on both Bus 2 and Bus 3. What "should" the settings be for this?
Message 13 of 21
(5,690 Views)
From you Capture.spy file I see that you're calling viUnmapTrigger before the viSetAttribute functions. Try calling viSetAttribute before the viUnmapTrigger calls, since that  way the segments in the chassis will be configured. I believe the viUnmapTrigger is failing because the chassis is not yet fully configured (i.e. trigger 6, but from which segment, etc.).
Message 14 of 21
(5,680 Views)
I moved the UnmapTrigger after the SetAttribute and still get an error, I guess I need to address this problem first.
Message 15 of 21
(5,666 Views)
any ideas on this?
Message 16 of 21
(5,638 Views)
Hi
From your Spy log, it seems that you have resources or devices in use when VISA is trying to access them to map the triggers.  We need more information, such as your setup or what else is running at the time when making calls to viMapTrigger. This information would be helpful so that we know what has control over the device(s).
At this point, I think you should call into NI support to get this issue resolved as quickly as possible.  An application Engineer will be able to work with you on what information we need to determine the issue.
Jerry
Message 17 of 21
(5,615 Views)
I was given a support ID # 710864 on 2/24 but have not heard back from anyone on this. This is the most important issue I have right now so I need to get going on resolving it. Anyone have any ideas?
Message 18 of 21
(5,543 Views)
Hi Tony
I just checked that number and it doesn't come up as a valid number.  How did you get it?  Did you talk to an Applications Engineer?  I think this requires someone who can coordinate different experts to bring the different issues together to solve.
Jerry
Message 19 of 21
(5,541 Views)
sorry, it's 7105864
Message 20 of 21
(5,539 Views)
