Signal Generators
trigger line conflicts
I have 10 5421 AWG's installed in a chassis (6 in PCX bus #2, 4 in PCX bus #3) operating as pairs through software control. Triggering works fine between the first 3 pairs but fails with the second two pairs with an error indicating that the trigger line was already allocated yet I cannot determine why the system thinks that. I have included a NiSpy capture. (note, remove the .txt extension to import into NiSpy)
Message 1 of 21
(9,813 Views)
Hi Tony
Do you have the PXI controller and PXI chassis configured in MAX?
Jerry
Message 2 of 21
(9,805 Views)
yes
Message 3 of 21
(9,802 Views)
Are you using NI TClk?   And only TClking the modules together that are on the same PCI bus segment?  Is this in one large application, or three applications running concurantly?
Message 4 of 21
(9,797 Views)
One application, we have 5 clocks in slots 2-6, and then 10 AWGs after that. Are we having some sort of clock signal line conflicts?
Message 5 of 21
(9,797 Views)
Hello Tony
It's hard to tell what your problem is from the information above. Please describe with more detail:
What chassis are you using?
What version of NI-FGEN are you using?
What are you trying to output with the NI 5421s?
Are you trying to start the signal generators with a HW trigger? All at once? In groups? One by one?
Where is this HW trigger coming from (if it's a HW trigger)?
Are you using NI-TClk to synchronize the NI 5421s?
How are you clocking the signal generators?
The NI-SPY log appears to be corrupted so that's not being very helpful.
Marcos Kirsch
Staff Software Engineer - Signal Generators
Marcos Kirsch
Chief Software Engineer
NI Driver Software
Message 6 of 21
(9,782 Views)
Hi Tony
Can you attach a MAX System Information report?
In MAX, go to the Help pull down menu and select “System Information”.  A window should pop up containing the software information.  At the bottom, a button labeled “Report…”.  Click on the Report button.
IN a new window, select “Simple Report” and select a directory to save it to.  Then click on the Finish button.  It will create an html file containing system information.  It is typically labeled: nireport.html.
Before sending it, please look at the file and verify that it contains a “Max Summary”, which should also list the modules you have and the slots they are in.
Also, we were able to open the spy file after Marcos's post.
Jerry
Message 7 of 21
(9,767 Views)
here you go
Message 8 of 21
(9,766 Views)
Hi Tony
Can you answer the questions Marcos posted?
I didn't see anything out of the ordinary in the nireport file.
J
Message 9 of 21
(9,756 Views)
I actually found a problem with viMapTriggers which may be helpful here. I have included an NI Spy dump of my application initialization. Are there some tricks involving mapping and unmapping of triggers that we are not catching? I also noticed that upon a clean reboot of the PC and external chassis the test case actually functions properly (at least the last set of AWG's that were previously reporting an error)
Message 10 of 21
(9,749 Views)
