Signal Generators
square wave with USB 6001 or 6002
Can I generate a hardware timed, 100 Hz square wave with a USB 6001 or 6002?
Message 1 of 10
(14,772 Views)
Hello salty,
The specification document for both devices (found at the links below) indicates that hardware timed analog output is possible on both devices.
SPECIFICATIONS NI USB-6001:
http://www.ni.com/pdf/manuals/374369a.pdf
SPECIFICATIONS NI USB-6002:
http://www.ni.com/pdf/manuals/374371a.pdf
Each device supports a maximum update rate of 5 kS/s simultaneous per channel, hardware timed. Therefore, you should be able to generate a hardware timed 100 Hz square wave using either device using an analog output task.
J_Bou
Message 2 of 10
(14,752 Views)
Thanks J_Bou,
Thanks for the information and the confirmation. I was able to use one of the examples to produce the square wave.
Message 3 of 10
(14,739 Views)
 with this devices can you get frecuency about 5000 Hz?
Message 4 of 10
(14,448 Views)
I tried to generate a 5 kHz signal but was only able to generate up to 2.5 kHz.
Message 5 of 10
(14,435 Views)
Hi, you used a Square Waveform VI or something else?
Message 6 of 10
(14,428 Views)
I used the analog output of the 6001 to generate the square wave.  I used the Voltage - Continuous Output.vi from the provided examples.
Message 7 of 10
(14,407 Views)
Thanks!
Message 8 of 10
(14,401 Views)
Did the voltage-continuous. vi examples work for you using NI-DAQ USB 6001 ?
Because for me it is not working, and then when I checked the requirements to run that circuit, nowhere it was mentioned about USB-6001
Could you please send me your vi file or help me with it?
I am fairly new to LabView and NI-DAQ.
Devansh
Message 9 of 10
(8,834 Views)
It works fine if you set it to work within the constraints of the USB-6001.  The sample rate for the USB-6001 is limited to 5kHz and the frequency output for the selected analog output must always be equal to or less than half the sample rate.
Message 10 of 10
(6,388 Views)
