03-06-2007 06:11 PM
03-07-2007 06:12 PM
03-08-2007 01:46 PM
Yes NI VISA is installed and the version is 4.0.1. I use the same computer to run the unpackaged program and the application.
03-09-2007 02:52 PM
03-09-2007 03:28 PM
03-12-2007
06:20 PM
- last edited on
06-10-2025
08:39 AM
by
Content Cleaner
Hello Houssine,
If you're using your executable on your development machine, then drivers shouldn't be an issue, they will already be installed on that machine. Specifically, you need to have any driver that you use in the executable installed on any machine that you run the executable on. I'd like you to test your executable on another machine, that does not have a LabVIEW Development installed. You'll need to install the Runtime Engine and NI-VISA, and you can do that by creating a custom installer. Also, this tutorial details Distributing Applications and may be helpful.
Meghan
