Signal Generators
VB6.0 and niFgen_init
My develop PC has the latest version NI-FGen (2.4.1), DAQ and I used VB6.0. A module is PCI-5411.
When I run under debug then niFgen_init gives -107413530 error (Failure loading driver).
When I built exe apllication then it runs well.
Any ideas?
(7,103 Views)
Hello Vasilich,
There is a known issue with Visual Basic and some of our drivers - try the registry fix mentioned in the knowledgebase and see if that solves your problem.
Drew Creel
NI Software Engineer
Signal Generators Group
Drew Creel
NI Software Group Manager
RF and Signal Generators
(7,095 Views)
Drew,
Thank you.
Changing register helped.
(7,085 Views)
