Signal Generators
The input digital waveform of DAC
I think there are two ways ,I'd like to know the differences.
First,this method is used to analog out.For some multifunction DAQ such as 6025E,we can use them to analog out,The digital waveform input to the DAC is generated by
"Basic Function Generator.vi",
Second,this method is used to test DAC.When we test DAC,we always use Digital Waveform Generator such as NI PXI-6562 to generate digital waveform ,then input them to
DAC directly.We analyze the output analog waveform to estimate the parameters of the DAC.
What is the differences between the two kinds of digital waveforms.Can we use "Basic Function Generator.vi" to generate high freq waveforms?What does it depend on?
If we use the first method to test DAC,does it work?
Thanks!
Any help would be grateful!
(7,219 Views)
I do not know much about your second method. However, for the first method, you can generate higher frequncy, by setting "sampling info" in "Basic Function Generator.vi" with a higher value.
(7,204 Views)
If you want to learn more about testing DAC,you can read NI tutorial "Evaluating High-Performance Digital-to-Analog Converters Using NI LabVIEW and Modular Instruments".
If we use the first method to test DAC,does it help?
Can anybody help me?
Thanks a lot.
(7,199 Views)
It depends on which parameters you want to test for your DAC and the precision.
(7,197 Views)
