Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
11-14-2012 03:56 AM
11-20-2012 01:31 PM
Hi Mylogic,
You may be experiencing the same issue the user in this thread was experiencing. Both of my posts describe scenarios that may lead to this issue. If none of those suggestions resolve your issue, then please send me a Fusion log from your system. A Fusion log is useful for troubleshooting issues with loading .NET dependencies. You can find instructions on how to create a Fusion log here.
11-21-2012 03:23 AM
Thank you for your reply.
1. In the thread that you recommand, he said " Install the driver to the target" . What driver he means ? NI drivers in the link is too huge. Installation is perfect on Win7 and Vista environment whihch do not have any NI driver, so I think my application does not need NI drivers.
2. I attached fusion log file. please refer it.
Thank you very much.
11-21-2012 01:28 PM
It looks like your application is having trouble locating System.Web.dll on the target system. This is a dependency of NationalInstruments.Common.dll, but is part of the .NET framework and should be installed into the GAC. Double-check that this assembly is on your target system in the GAC. What version of the .NET framework do you have installed on the target system, the Full framework or the Client Profile? You will need the full version for National Instruments assemblies.
