Signal Generators
Real-Time Waveform Arithmetic & Output NI-9264
I am quite new to LabView, and have what I hope is a problem that is easy to solv. I am currently trying to simulate a sine wave in LabView in realtime, sum it with a noise waveform (or other waveform) then both display the resultant waveform continuously on a chart, and output it through a NI-9264 analog output until the program is halted. There is an example in labview of how to simulate this waveform math, but not continuously (screenshot below, I can't remember the name of the example VI). I have tried to connect simulate signal blocks to arithmetic blocks, but that gives an error.
If someone here is able to provide me with an example for me to work with I would be very grateful, and any help would be greatly appreciated!
LabView 2014 SP1
NI-CRio with NI-9264
Stefan Hall
(3,946 Views)
I apologize for this post. I realize I must have done something wrong before. Performing mathematical operations on realtime waveforms certainly works. (I'm not sure how to delete this post)
(3,914 Views)
