Signal Generators
RFSG Demo panel
Is any (PXI 5670)RFSG demo panel or Example for simple Signal generation without modulation.vi is available with NI
(7,518 Views)
I believe the example you are looking for is the RFSG Single Tone Generation.vi example. This example can be found by going to Start>>National Instruments>>NI-RFSG>>Examples then selecting the appropriate development environment. I hope this helps!!
JaceD
Signal Sources Product Support Engineer
(7,511 Views)
Thanks for ur reply
yes correct i m looking single tone generation but i cant find any example option in NI RFSG menu.
can i use RFSG FM generate.vi with 0Khz deviation without message signal.
(7,502 Views)
I am unsure as to why you do not see the examples in your menu; I would suggest reinstalling the driver and verifying that the examples are installed with your driver. I have provided a screen shot of the block diagram of the example program if you wish to build this VI yourself (the false case is wired straight through).  I also do not believe you will be able to set the parameters to 0 on the RFSG Generate FM.vi I have tried this and receive an error.
Message Edited by jaced on 02-13-2008 11:01 AM
JaceD
(7,488 Views)
hi Jace,
             I will try single tone sine wave generation as u mentioned above & i'll message u wats the status for this test.
 Thanxs for ur response.
(7,461 Views)
