Signal Conditioning
specific range
I have acquired some data(Magnitude versus frequency), I want to just select the points which are in specific range(their frequency.....X-axis), for example I want to filter the signal only for the points which are between 20Hz and 30Hz. Does anybody know how can I do that?
I used "In range and coerce", but it gives the "lower limit" for the points which are not in the rang. I don't want it to pick that points.
I'd appreaciate it.
Petar
(5,694 Views)
Accepted by topic author Petar2015
I think you could try using a For Loop instead of the "In Range and Coerce" function. You just input your data into the For Loop, and using a conditional tunnel you can compare the data that you want. I attached a picture of a little example I created for you to see.
(5,676 Views)
Thanks so much, It was really helpful.
Petar
(5,665 Views)
You are welcome!
(5,662 Views)
(5,638 Views)
