Signal Conditioning
preventing false trigger in S series Device
I have a PXI 6133 and currently have a task set up to begin with an analog edge trigger, however the line experiences a fair bit of noise due to solenoid power lines. I know that some other devices are able to use the minimum pulse width option in the daqmx triggering property nodes, but as far as i can tell S series devices don't. Does anyone know of a work around for this.
(4,702 Views)
Hi fchacon,
One approach may be to reduce the environment-induced noise in your system. The Field Wiring and Noise Guide could be a good starting point for you.
Another possible option is using an Analog Edge Reference Trigger that accounts for the noise in your system. This may allow you to set a trigger higher than the desired level, but incorporates the noise from our environment.
Briana P.
Licensing
Sr SW Engineering Manager | NI R&D
ni.com/support
(4,678 Views)
If you have a spare analog input (and have a low impedance source),  you can try a simple analog lowpass filter (RC) ....      but doing the cabling rigth and reduce EMI is always the best option
Greetings from Germany
Henrik
LV since v3.1
(4,667 Views)
