Signal Conditioning
is PCI-6036E suitable for me to send out analog signal to controll a device?
Hello
 I need to controll and generate an analog signal to control a nanopositioning stage and I would like to know which one will be better using PCI-7344 board through UMI-7764 or using PCI-6036E board through SCC-68 I/O connector. additional question, I have actualy four wiring pigtailed with LEMO connector, the LEMO connector have two PINs which will be connected to the device, and the 4 wires which will be connected to the signal conditioner, the two pins Ain+ and Ain- with respect to the device, the other 2 wires one is the shield ground and the other one is ground also, the device is CGND, shall I connect the only two differential wires which will be connected in the analog out at the UMI-7764 snd the other one in AOGND at UMI-7764, and the other 2 will be ignored. please may I get any help or advice with full of thanks.
 Aneece
Message Edited by Aneece on 04-09-2009 10:22 AM
Message 1 of 1
(6,561 Views)
