Signal Conditioning
integrate pulses from oscilloscope
Hello!
I get signal pulses from oscilloscope. Could you please help me to integrate each pulse separately. I've found simple examples and tryed to create loops as in the C++, but it doesn't seem to work properly. Thank you very much!
Arev
(5,313 Views)
Hi Arev,
Are these digital trigger pulses from the scope?
What sort of output do you need from your code. You could use a counter input (if available) to do the integration for you - this would provide you with count values which you can sum to give you a continuous integrated value.
Alternatively, if the signal is analogue and varies, you could use analogue acquisition and have a threshold trigger which could either add to a variable (if your signals are pulses), or the signal can be sampled and it's amplitude integrated.
If you could tell me more about which better suits you, I can provide more info.
Kind Regards,
(5,285 Views)
