04-05-2013 05:50 AM
Hello!
I get signal pulses from oscilloscope. Could you please help me to integrate each pulse separately. I've found simple examples and tryed to create loops as in the C++, but it doesn't seem to work properly. Thank you very much!
Arev
04-09-2013 03:34 AM
Hi Arev,
Are these digital trigger pulses from the scope?
What sort of output do you need from your code. You could use a counter input (if available) to do the integration for you - this would provide you with count values which you can sum to give you a continuous integrated value.
Alternatively, if the signal is analogue and varies, you could use analogue acquisition and have a threshold trigger which could either add to a variable (if your signals are pulses), or the signal can be sampled and it's amplitude integrated.
If you could tell me more about which better suits you, I can provide more info.
Kind Regards,
