Signal Conditioning
Signal detection by NI SCC-68
Please help me.
I used to use the NI SCC-68 with Labview 8.6,  it works well, the room temperature is 24 degree C with noise up and down (23.0~25.0).
I now try to use it in a new computer with Labview 18, it keep the constant value of 220 without any fluctuation, when I try to use it now.
The NI SCC-68 is connect to PCI 6229, I already  do the configuration in the Measurement &Automation Explorer, the setting is exactly the same as the old computer.
Do anyone meet problem like that? Any suggestion on that problem?
(2,877 Views)
There might be drivers missing that are preventing the device from working correctly. Please make sure that you have DAQmx installed on your computer. Here is a download link for it.
https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html#291872
(2,839 Views)
