Signal Conditioning
Selected wrong thermocouple type
Dear all,
I erroneously selected the type J thermocouple instead of type K when using the NI USB-TC01. I would really be happy, if anyone could tell me, how I can now calculate the correct temperature from my measurement data?
(6,343 Views)
Step 1: Google "type j thermocouple characteristic".
Step 2: Find this amazing reference document: https://www.omega.com/temperature/Z/pdf/z021-032.pdf
Step 3: Find the polynomial terms for a J type and a K in Table 4 on page Z26
Step 4: Derive the original sensor voltage using the J terms and recalculate the temperature using the K terms.
I do not know whether the cold junction compensation needs to be looked at as well.
(6,337 Views)
That's my main problem: Which temperature is assumed for the cold junction?
(6,314 Views)
Accepted by flo87
all TC conversion polynomes are already available in LV 🙂
And shure, you need at least a good guess of your CJC temperature 😄
I added a vi to correct and get an idea how big the error due to wrong CJC migth be.
Greetings from Germany
Henrik
LV since v3.1
(6,296 Views)
Accepted by flo87
Vielen Dank, Henrik!
Meanwhile I found, that there is a temperature sensor inside the NI USB-TC01 measuring the cold junction temperature to compensate it. And it seems like the electronics around the cold junction create a quite stationary temperature somewhere at 32°C after some warm-up time.
(6,293 Views)
