‎04-25-2006 07:44 AM
I have a SCXI-1000 chassis controlled by a 6221 under Daqmx 7.5. At the time of the configuration with MAX, the SCXI-1000 is not recognized.
I manually configure the SCXI-1000 by putting the charts which are present. When I ask him to make an initialization of the charts or SCXI-1000, I have a message which says to me that the SCXI-1000 does not exist or not connected. However I am certain at 100% that all is well connected. I do not have address problem.
When I automatically configure the SCXI-1000, I have the same error message.
If I connect the SCXI-1000 on a PCI-DIO-16-E4 under Daqmx 7.5, the SCXI-1000 is recognized and all functions.
I tested with two PCI-6221 and two 68 points cables and that does not work.
slot1 : 1125+1313
slot2 : 1112
slot3 : 1180+1302
slot4 : 1161
What is the problem?
‎04-26-2006
10:47 AM
- last edited on
‎07-16-2025
12:19 PM
by
Content Cleaner
Which cable do you use beetwen PXI-6221 and SCXI-1000 ?
Can you try make the same test (install SCXI) without SCXI-1125, but only with the SCXI-1112 in slot 1.
Can you try install the new driver version ?
Here is the link :
http://digital.ni.com/softlib.nsf/websearch/D31D46FFFB745ECA862571490053EAB8?OpenDocument
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
‎04-27-2006 02:33 AM
I use the good cable between the SCXI1000 and the 6221
I use the good versio on the Daqmx
With 1, 2 or 3 modules on the SCXI 1000, the problem exist
With an other module like 1112 on slot 1, the problem exist
‎04-27-2006 02:41 AM
What's the part number of this cable (or name) ?
Christophe S.
‎04-27-2006 02:47 AM
SHC68-68-EPM
‎04-27-2006 02:52 AM
Ok, Try to install the new version driver, and let me know if the problem are the same.
Christophe S.
‎04-27-2006 02:57 AM
I already have the new version of the driver and the problem still exist
The 3221 alone without SCXI 1000 work perfectly well.
‎04-27-2006 03:15 AM
Are the chassis with address 0 ?
Jumper are set like this image :
Which revision are your chassis ? (part number of you chassis with the letter)
Christophe S.
‎04-27-2006 03:38 AM
I try with adress 0, 31 and one intermediate
chassis part number : 81445L-31 Rev 4.0
serial 10ACA4C
‎04-27-2006 08:16 AM
Christophe S.
