Signal Conditioning
Range exceeding detection
I'm currently updating my projects by using DAQmx contrary to traditionnal DAQ which I used up to now.
Indeed, I have bought PCI-6251 card that only supports DAQmx.
The update is now OK but I have had a request for a long time that perhaps can be possible with DAQmx :
I would want to detect an possible range exceeding during a acquisition (for example, if I configured a max value equal to 1V and I measuring a 2V signal).
Thanks by advance for helf
Nicolas
France
(4,951 Views)
If you exceed the range you configured you should be able to see a saturation of the measured signal ( at 1 Volts in your example).
Message Edité par ClementG le 11-13-2007 11:19 AM
ClémentG
(4,924 Views)
