Signal Conditioning
Measuring the voltage of series connected batteries
Hi, I am using the ADC of PIC18 to measure the voltages of the battery bank in which the batteries are connected in series. I have to measure the voltages of each battery in the bank. I am using differential op-amp with voltage divider to bring the voltage into the range of the ADC. Now as the batteries are connected in series so when I connect it with the circuit it is measured as zero. while not connected in series the measurement is fine. I need soluton for this problem any help will be greately appreciated. what should I do to measure the battery voltages while connected in series. Thanks
If you are young work to Learn, not to earn.
Message 1 of 17
(11,513 Views)
Do you have a wiring diagram or circuit to show your setup?
What is the voltage of the batteries?  What is your supply voltage for the Op-Amps?  How many batteries?
What I'm guessing is that the common-mode voltage of the battery is higher than the supply voltage and therefore both sides of the differential op-amp are railing and therefore no difference.
Message 2 of 17
(11,505 Views)
I agree with crossrulz. The problem is likely in the way you have connected everything.
If you have a battery pack for an electric car or an uninterruptible power supply where the total battery voltage reaches hundreds of volts, you have a significant challenge to make the measurements.
Please tell us the number of cells, the maximum battery voltage, and the accuracy and resolution required.
Lynn
Message 3 of 17
(11,499 Views)
There are 4 12V Batteries connected in series and I am taking the + and - of each battery to my differential op-amp. The last battery connected in the series connection is measured fine ,but when I connect the others the result is zero. I think due to the series connection the difference at the op-amp input is zero thats why I get zero at the output. A sample pic of the connections is attached.Please suggest solution.
Message 4 of 17
(11,482 Views)
What are your supply voltages for the op amps?
Message 5 of 17
(11,472 Views)
Its 5V on the positive and Ground on the negetive.
Message 6 of 17
(11,462 Views)
Then you are guaranteed to have five dead op amps! You cannot connect 48 V, 36 V, 24 V, or 12 V to an amplifier powered from 5 V.
Maybe your amplifiers can survive, depending on the voltage dividers.  Please show us the complete circuit with the dividers and the power connections.
Lynn
Message 7 of 17
(11,458 Views)
I have voltage dividers to take care of that....
Message 8 of 17
(11,452 Views)
I still suspect that you have a common mode voltage problem or something not connected correctly.  Without a complete schematic, it is useless to spend any more time guessing.
Lynn
Message 9 of 17
(11,442 Views)
My 2c:
build for every input (also for the GND)  1:200 voltage divider with 2x 270k and one 2.7k  , add 1nF cap parallel to the 2.7k (unless you want really dynamik measurements)
choose a intrumental diff amp with gain 40 and make shure you choose a type that support inputrange to GND.
you can add a 4.096V Ref to the ADC ...
the 0.5M input resistor together with the input diodes of the IA should work as a input protection...
Greetings from Germany
Henrik
LV since v3.1
Message 10 of 17
(11,438 Views)
