Signal Conditioning
How to generate noise spectrum curve?
I use computer sound card and acquire sound (noise) from a microphone. I try to do FFT transformation and would like to display the noise spectrum like the picture shown below. But I don't know how to do the FFT.
(3,286 Views)
It's not only the FFT 😉
These vis can be found in the signal processing menue..   (Seems that you need to make some training in LV first)
Do you have the Sound&Vibration toolkit?
It will do all that fancy A-Filtering.... and scaling....
For the scaling:
And you migth need a calibrated mic and ... a soundcard ... ..mmh
So you migth also need a pistophone to do the scaling rigth
Greetings from Germany
Henrik
LV since v3.1
(3,258 Views)
(3,229 Views)
