キャンセル
次の結果を表示
次の代わりに検索
もしかして:
Full bridge strain gage shunt calibration
The shunt calibration DAQmx wizard provides the option to select one of the bridge completion resistors to shunt for the calibration. How should I select which one will be used for a shunt calibration of a full bridge III configuration? I'm using an NI-9237 bridge measurement module.
0 件の賞賛
メッセージ1/3
2,953件の閲覧回数
We also use the NI-9237 and as far as I know, the only settings which can be adjusted are
  • excitation voltage and
  • enable half-bridge completion
by right-klicking on the cRIO-Module in the Project tree.
Good luck
0 件の賞賛
メッセージ2/3
2,927件の閲覧回数
Hello Testr00,
You can find more information in these documents: Connecting Strain Gages and Shunt Resistors to the NI-9237 and Measuring Strain with Strain Gages.
I hope this information is useful for you!
All the best,
0 件の賞賛
メッセージ3/3
2,921件の閲覧回数
