Signal Conditioning
Filtering signal to prevent flickering of the output.
Hello
I am using Labview 2010 and a usb 6008 DAQ to acquire two signals from  a 555 timer circuits with LDRs and  I am measuring them and comparing them. The idea is that when one of them is greater than the other I will generate an output. My problem is that even though I have allowed for +- 10 tolerence , I am still getting a flickering output once the treshold has been exceeded. Can someone give me any ideas because maybe I am approaching this completely the wrong way. The VI I have attached is using a simulate signal tool to represent my input signal.
Bye
(5,953 Views)
Hello Darren,
I presume that the 555 timers are producing the signal for a light source and that the LDR are triggered off that source? Are the LDRS completely shielded from alternate light sources? What output are you generating? Can I see the code you are using for the acquisition on the DAQ side?
Regards
Andrew George @ NI UK
(5,942 Views)
Hello
The 555 timer circuits are producing the signal to be compared with each other and motors will turn depending on which on has the greater frequency. The output I am generating is for driving stepper motors hence the reason for producing the pulse in the case structure.
Thank you
(5,940 Views)
Hello Darren,
Is there any reason you haven't considered SoftMotion for your application? As far as exactly what you are trying to achieve with the timers Im still a bit lost as to what the problem is? What behavior are you seeing that is unexpected? So from what I gather is that you are measuring two frequencies and trying to establish which one is greater? I have written a VI to show you a simple yet effective way of doing just that. I have modeled it appropriately for the up and coming red nose day. Please see attached code. Enjoy!
Regards
(5,921 Views)
