‎02-01-2017 12:09 PM
Hi there,
I have many sensors to communicate with using labview, and one of which is an audio sensor. for the audio sensor i intend to use the sampling frequency of 44100Hz and for the other sensors a sampling frequncy of 1000Hz. is it poosible to use the same DAQ assistant? if not, how can i go about it.
tjuy
Solved! Go to Solution.
‎02-01-2017 01:33 PM
For different sampling rates, you will need different devices. Put all of the channels at 1kHz on one DAQ and the channels at 44.1kHz on a second DAQ. You will then also need two use multiple DAQmx tasks, one per DAQ. Each task uses a different DAQ Assistant.
‎02-11-2017 03:15 PM
Hi everyone!
I was wondering if somebody could help with this one. I have got audio signal from four sensors that I want to save at the of a while loop, I tried using build array vi then to write to spreadsheet vi, but whenever I opened the file I could only see two rows one column of the data. And I expected to see four columns of numerous rows. Please advice on such a problem. Thanks.
