11-11-2005 11:49 AM
11-14-2005 06:34 AM
11-14-2005 07:40 AM
11-14-2005 08:15 AM
11-14-2005 08:45 AM
Greatly appreciate the feedback. Should have mentioned that due to impact testing we need high sample rates so the most suitable and inexpensive config seems to be the ACC01 Module for the SC-2345, PCI-6251. I will then proceed with a voltage divider to reduce the +11V max IP from the Accelerometer to a +5V max to meet with the ACC01 Input Voltage. It will work out at under 1200 Euro which is well within the budget.
My main worry was with signal interference if I interrupted the raw signal from the accelerometer but from feedback this does not seem to be a problem.
Again appreciate the help, look forward to using forums in the future.
11-14-2005 08:52 AM
11-14-2005 09:44 AM
11-14-2005 10:39 AM
Thank you for the information. It's difficult to see if the accelerometers will be compatible, although it looks like the powering of 24V and 4mA will be OK. However, the input seems to be differential, and most accelerometers that I have come across are single-ended. The Dytran series are compatible with what is often called 'ICP' powering, which is sometimes referred to as Isotron, Deltatron, etc, and I'm sure if you went to National and asked them if they are compatible with ICP, they will confirm. Many of the other National Instruments input cards I have used have ICP powering as standard, and these work fine, but I am not familiar with the SCC-ACC01,
11-14-2005 10:56 AM
11-14-2005 12:14 PM
