Reference Design Content
NI LabVIEW FPGA Floating-Point Library
Introduction
Note: This library is not officially supported nor this page currently monitored.
Floating point math operations on FPGAs are important for many control and simulation applications. In LabVIEW FPGA, most math operation nodes in the Numeric and Comparison palette support the single-precision floating point data type. However, these primitive nodes cannot run inside a Single-Cycle Timed Loop to achieve higher performance. Additionally, these nodes cannot be configured for resource optimization at the cost of performance. The NI LabVIEW FPGA Floating-Point Library solves this problem by providing IP which can be optimized in the following ways:
  1. Resource Optimization: You can save resources by sharing multiple instances of an IP when running outside Single-Cycle Timed Loop. Please note that there is IP in the library that does not support resource sharing. The reason for this is that they use very few resources and resource sharing is not applicable.
  2. Performance Optimization: You can achieve better timing performance by running the IP in a Single-Cycle Timed Loop. Please note that only a subset of the IP in the library supports running in this mode.
System Requirements
Software Requirements
The NI LabVIEW FPGA Floating-Point Library was designed and tested with the following software packages:
  • LabVIEW 2015 or later
  • LabVIEW FPGA 2015 or later
Hardware Requirements
The NI LabVIEW FPGA Floating-Point Library supports compiling and running on all Vivado compatible targets. Please refer to the  Compatibility between Xilinx Compilation Tools and NI FPGA Hardware document to determine if your target utilizes Vivado.
 IP List
The NI Floating-Point Library contains following IP. All IP only supports single-precision floating-point input and output.
IP Names Supported Outside of Single-Cycle Timed Loop Supported Inside Single-Cycle Timed Loop
  • Add
  • Subtract
  • Multiply
  • Divide
  • Increment
  • Decrement
  • Square
  • Square Root
  • Reciprocal
  • Exponential
  • Natural Logarithm
  • Equal
  • Not Equal
  • Greater
  • Greater Or Equal
  • Less
  • Less Or Equal
Yes (with resource sharing) Yes
  • Absolute Value
  • Sign
  • Negate
  • Equal To 0
  • Not Equal To 0
  • U32 To SGL Cast
  • SGL To U32 Cast
Yes (without resource sharing) Yes
  • Scale by Power Of 2
  • Power Of X
  • Sine
  • Cosine
  • Sine & Cosine
  • Quantizer
  • In Range and Coerce
Yes (with resource sharing) No
Performance Benchmarks
Inside a Single-Cycle Timed Loop
All IPs used inside a Single-Cycle Timed Loop can be compiled and run at clock rate of 40MHz. The following table shows the latency of all IPs running inside Single-Cycle Timed Loop:
IP Names Latency in Cycle(s)
  • Add
  • Subtract
  • Multiply
  • Increment
  • Decrement
  • Square
  • Equal
  • Not Equal
  • Greater
  • Greater Or Equal
  • Less
  • Less Or Equal
  • Absolute Value
  • Sign
  • Negate
  • Equal To 0
  • Not Equal To 0
  • U32 To SGL Cast
  • SGL To U32 Cast
0
  • Divide
  • Square Root
  • Reciprocal
5
  • Exponential
  • Natural Logarithm
2
Outside a Single-Cycle Timed Loop
All IPs used outside Single-Cycle Timed Loop can be compiled and run at clock rate of 40MHz. The following table shows the ideal latency of all IPs running outside of a Single-Cycle Timed Loop. Please note that this latency could increase when using the resource sharing feature of the library:
IP Names Ideal Latency in Cycle(s)
  • Add
  • Subtract
  • Multiply
  • Increment
  • Decrement
  • Square
  • Equal
  • Not Equal
  • Greater
  • Greater Or Equal
  • Less
  • Less Or Equal
  • Absolute Value
  • Sign
  • Negate
  • Equal To 0
  • Not Equal To 0
  • U32 To SGL Cast
  • SGL To U32 Cast
1
  • Divide
  • Square Root
  • Reciprocal
15
  • Exponential
  • Natural Logarithm
3
1
  • Power Of X
10
  • Sine
  • Cosine
  • Sine & Cosine
39
  • Quantizer
32
3
Comments
Pie566942.0
Member
Member
on
Unfortunately this library is password protected, so we cannot review it, so we cannot use it in AS9100 design and production test.  Please make the password available, even under NDA, so we can take advantage of this IP.
Steve K
AmitShachaf
Active Participant
Active Participant
on
Hi KS30,
I would like to use the library. How do I get the password to make it work for me?
Amit Shachaf
