tpc-2012 cannot read shared variable
I have a TPC-2012 and cannot read shared variables with it. I hosted the Shared Variable on a cRio-Controller. On another PC the variable is read correctly but not on the tpc-2012. What can I do? No error messages appears on the TPC-2012 (Windows CE 5). Also the TPC cannot write values in a Shared Variable.
Christian
(4,143 Views)
Accepted by cosw
What version of LabVEIW Touch Panel are you using? I am not sure why shared variables are not working properly on your device. The TPC-2012 comes with preinstalled support for shared variables and it could be possible that it has been removed or corrupted. Here are some steps you can follow:
Installing Support for Shared Variables
How Do I Install Support for Shared Variables on the TPC-2012?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,142 Views)
Can any body help me that to read a shared variable analoge ta in dyanamic event structure. I have use Tag Reader VI to do some but i experience too much dely in first run mean first time it take too much time. /media/disk/event str and Tag reader.bmp
(3,756 Views)
