01-09-2012
10:11 AM
- last edited on
04-26-2025
08:55 PM
by
Content Cleaner
I know this post is old, but I wanted to close the thread with a link to our most complete documentation for the RIO Mezzanine Card DIO.
First, the user manual is officially published and linked here:
NI sbRIO-9605/9606 OEM Operating Instructions and Specifications
Second, a whitepaper discussing the DIO lines in more detail:
NI sbRIO-9605/9606 RMC Digital I/O Capabilities
Hopefully this helps anyone who finds this thread later.
Cheers,
04-24-2012 12:01 PM
Not really: "Error: HTTP Web Server: Lotus Notes Exception - Document has been deleted".
04-24-2012
02:50 PM
- last edited on
04-26-2025
08:55 PM
by
Content Cleaner
Sorry for the inconvenience. It appears that the link to the manual has changed.
The current link is:
I don't know how reliable the link is in the dynamic user manual system on ni.com, so in case this link fails in the future, the consistant way to find the manual is to navigate to the product page, click on the resources tab, and then click "Manuals". From the manuals page should be a consistent link to the Operating Instructions and Specifications.
07-03-2012 04:59 AM
As per "OEM OPERATING INSTRUCTIONS AND SPECIFICATIONS" of Aug 2012.
"The DIO channels on the NI sbRIO device are routed with a 33 characteristic trace impedance". Is it true for 3.3V DIO on RMC Connector??
07-06-2012 10:52 AM
Hi Rasesh,
I am not positive what you are asking. But here is my best answer.
The DIO lines on the sbRIO are routed with 33 Ohm characteristic impedance, as you found in the manual. These lines all go through the RMC. If you are designing a board to connect to the RMC, you should match the 33 Ohm as best you can.
Cheers,
Ryan
07-12-2012 02:45 AM
Hi Ryan,
Please find attached old manual for your Information.(with 55 ohm ch. trace impedance)
07-12-2012 11:20 AM
Sorry for the mistake, and thanks for catching it and bringing it to our attention, Rasesh.
The latest version of the manual accidentally duplicated the series termination resistor value (33 Ohm) to the trace impedance specification (55 Ohm). You are correct, the trace impedance of the sbRIO DIO Lines to the RMC connector is 55 Ohms. We will ensure the manual is corrected as soon as possible.
Cheers,
