07-10-2012 08:51 AM
Hello.
We are developing a system which requires real-time high speed acquisition and data analysis. There are 4 PCI Express boards that simultaneously send ~5 MB of data to the PC at ~1-2 sec. interval. For each ~5MB a polynomial fit is performed and the result is saved.
Is it possible to develop the program using LabView?
Thank you in advance.
Cristina
07-11-2012 09:33 AM
Hi sen_crystal, could you provide the names of the PCIe boards? Thanks
07-13-2012 07:29 AM
Hello.
We don't know yet. We would like to know if LabView is suitable for this kind of application.
Cristina
07-13-2012
12:14 PM
- last edited on
05-15-2025
01:22 PM
by
Content Cleaner
That's definitely possible. Since your application involves with large data volume, I would recommend using the producer/consumer pattern. If you have LabVIEW installed on your machine, please use example finder to locate the shipping examples.Otherwise, you can download the 30-day trial version from here.
Per your reply, I am curious if you have already purchased the PCIe cards. If not, you have the option to use the NI-DAQmx simulated device. Otherwise please check PCI Express or contact NI Support.
