Sampling Problem with Flexrio
Hi ,
I have Problem with Flexrio. I get signal parts that do not exist normally. Here is a picture.
(4,148 Views)
Hi labview_jumper,
I'm assuming that you're use to cRIO or R series since the FPGA code you're showing (right?).
Actually, Analog FlexRIO adaptor Modules have their own clock, so you usually want you're AI node to be inside a SCTL running at the AI Clock rate.
Which module are you using? I'd suggest with give a try to the LabVIEW example associate to that module, that will give the architecture basis you should respect to use your FlexRIO.
Have a good day,
(4,061 Views)
Hello ,
I am using NI 5752  with 7966R. I am also getting wierd signal shapes even when running their example programs. I can see that gain is varying at different frequencies even without any gain control implementation. What may be the reason for this? Any idea?
Thank you,
Mithun
(3,970 Views)
Hello Mittu1,
I dont mind you post on that thread but you might get more answer creating a new one 😉
concerning your issue with the 5752, this make me think about an issue I have faced.
Can you tell us more about the signal you're sampling? The 5752 is design for ultrasound so there is a filter with a 16KHz cutoff frequency.
(see http://www.ni.com/pdf/manuals/375573a.pdf or http://www.ni.com/pdf/manuals/373035b.pdf).
So you cannot trust any result you're seeing about the gain if your signal frequency is lower 16KHz.
I hope this help.
Have a great day,
(3,966 Views)
Hi Florent,
No i am working with ultrasound signals. If coming below 100 KhZ signal amplitude is very much high and at higher frequencies above 1 MhZ, it is coming down drastically. Really wierd behaviour. Can you suggest me any way to solve this?My signals are in the range of 200 khz to 6 MhZ. With very low amplitude..Say 10 mvpp.
Thank you,
Mithun
(3,961 Views)
Hi Mittun,
did you try to use the 5781 example in which you can configure the ADC? Which anti-aliases filter do you use (7.5MHz, 10MHz or 14MHz)?
That can explain a lot about the amplitude variation you're seen 🙂
(3,922 Views)
I tested NI 5752 with PXIe-7961R by using ConfigureDAC example.
Input signal is square wave of 500 KHz through SMB-2145.
Output is not square wave but half square half triangle wave.
I attach the photo of output wave.
I don't known how to solve this problem.
Do you know how to solve its? Please tell me if you know.
(3,873 Views)
