 Charlie_P
			Charlie_P
			05-07-2009 03:28 PM
Good Evening quarterlbr,
"i leave the card mounted until the program is terminated, so it should retain the drive letter - correct?"
Yes, correct.
As I asked of Jolt in my first post of this thread, "Are you able to connect to the drives under your controller in MAX? You can accomplish this by right-clicking the controller under Remote Systems in MAX and selecting File Transfer. Which drives appear under Remote Directory?" You will need to attempt this while that drive is mounted.
 quarterlbr
			quarterlbr
			05-11-2009 08:10 AM
Thanks for the reply.
I don't know if I missed it somewhere in the thread or forum, but It turns out that there is a bug in Rio 3.1.0 that won't allow, for some reason, the SD card's assigned drive letter tp be seen on an ftp connection. I upgraded to Rio 3.1.1 and the problem was solved.
Thanks for all your help!
