09-28-2015 06:23 AM
I tried to communicaste with my cRIO -9004 using ethernet cable which is connected with same subnet mask as that of PC.It is mounted on the chasis cRIO 9104 which has a reconfiurable FPGA and 8 slots.
But I couldn't find cRIO-9004 in the NI MAX window which specified the chasis as unkown.
I am anew user to this module and software. Please help
10-07-2015 04:17 PM
Hey Vinayak,
I'm not sure that there's a problem here. You wouldn't usually do anything with the modules in MAX. Are you able to add them to your project in LabVIEW?
