can't output a right answer from divide function in sbRIO
I'm using sbRIO 9636 to generate a sine wave with an amplitude of 1V. The divide function in my FPGA VI seems have some problem.
For example, if I divide 1 with 1, the answer is 1 when I chose integer output type. But when I chose single floating point output type, the answer is 1.07E9. I found this is 2^32, but don't know why and how to fix it.
Jiaqi
(5,381 Views)
I think the problem may due to the floating point calculation in FPGA.
If I do need floating point calculation in FPGA, can I add a time delay in the loop to guarantee that there's enough time to do this?
(5,358 Views)
Hi jwan887,
I haven't seen the same behavior myself on the FPGA, when simply testing all single floats and a divide function inside a while loop, with no other processing in the background on a similar sbRIO.
You shouldn't need to change the loop timing, as single floats aren't usable in single-cycle timed loops, and in a regular while loop the code should throw a compile error if the timing isn't met.
Could you post a screenshot of the relevant section of your code?  I'd like to see what else is going on that could cause this issue.
(5,347 Views)
It may also be useful to list the versions of your software you notice this in.
Tannerite
(5,343 Views)
